nasha avatar image
nasha asked
VRM API Battery Monitor - Top & Bottom Section Voltage...
Hi, I'm using the VRM API to retrieve data fine, but I can't seem to find the values for a Battery Monitors Top & Bottom Section Voltage... I've found Mid-Point Voltage and Deviation but not the Top and Bottom Voltages.
I can see the VRM portal has both the historic values, is the data currently exposed via the API? If yes, could you let me know the code I should use.
Thanks & Regards,
--Andy
VRMBMV Battery Monitorapi
