jfisher avatar image
jfisher asked
Blue Smart IP22 30a charger internal sensor overrides bmv-712a temp for low-temp cutoff
I have 2 Blue Smart IP22 30a chargers in sync with each other and a BMV-712a to receive battery temperature. My LiFePO4 batteries are heated in an external battery box. When on A/C power and the temperature drops below freezing, even though the batteries are at 50 deg. F (10 deg. C) the chargers are remaining shut down due to low temperature where the chargers are located. This appears to be a firmware bug, I cannot find any options to set temperature priority to external via v.e. smart networking or internal.
Is that a known issue? Is there a firmware fix planned for this?
Regards,
Lithium Batterytemperaturebluesmart ip22VE.Smart Network
kevgermany avatar image
kevgermany answered ·
Not sure what you mean by BMV712a, but the standard BMV712 has no temperature sensor. I couldn't find it with an a suffix as a product.
