simonsamimi avatar image
simonsamimi asked
Error Message: 'No VE.Bus product was found' Error: mk2vsc-33 and then Error: 1391
having major issues trying to update my multiplus 122/3000/120.
im getting an error No VE.Bus product was found' Error: mk2vsc-33 and then i get error 1391.
I have a
Product Cerbo GX
Firmware version v2.73
and ALSO
Product
MultiPlus 12/3000/120-16
Firmware version 430
Last connection 2022-01-22 20:41:52
Product id 2609
VE.Bus connection VE.Bus
Hardware configuration Single unit
VRM instance 276
CAN SOMEONE PLEASE HELP ME WITH THIS, IM ABOUT TO PULL MY HAIR OUT haha
VRMmultiplus ve.buserror
https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
At which point do you get that error? Can you make a screenshot?
Is the connected and switched on?
Last connection 2022-01-22 20:41:52 - is that your local time?
Normally "Last connection" should be "one minute ago" or something like that.
I would always recommend to do the update locally with a MK3 interface.
simonsamimi avatar image simonsamimi commented ·
i dont have an mk3 and im going away in 5 hours.
I just need to update the mulitplus so i can use it. ive been trying to do the update on the vrm portal
Matthias Lange - DE avatar image Matthias Lange - DE ♦ simonsamimi commented ·
I don't know what that "boot mode" means.
Do you got that same error since the first try or did you start the update at one moment?
Do you have physical access to the system? Is the MultiPlus still running or is it off and wont turn on?
Maybe it is suck now. In that case the only way is an update via MK 3 Interface.
