luc-bosmans avatar image
luc-bosmans asked
What is VE.Bus Error 9
I got this sequence of errors (see below) in a setup with 3 * Multiplus II.
The system was restarted manually and all is fine again now.
Where can I find info about VE.Bus Error 9?
This error showed up 15' before the system went in protection.
Thank You,
Luc.
275 VE.Bus System [275] VE.Bus Error: VE.Bus Error 24: Switch-over system protection initiated 2024-01-26 12:20:50 2h, 36m, 32s
275 VE.Bus System [275] VE.Bus Error: VE.Bus Error 9 2024-01-26 12:05:05 1m
275 VE.Bus System [275] VE.Bus Error: VE.Bus Error 9 2024-01-26 12:05:06 28s
275 VE.Bus System [275] VE.Bus Error: VE.Bus Error 17: Phase master missing 2024-01-10 12:05:57 6s
275 VE.Bus System [275] VE.Bus Error: VE.Bus Error 17: Phase master missing 2024-01-10 12:04:36 7s
multiplus ve.buserror
