bcoffel avatar image
bcoffel asked
Realtime Reporting has just stopped
I have been successfully monitoring my onboard solar system on my RV for months now using the VRM Portal and just a few days ago it just stopped. I was in my RV just yesterday and was able to monitor the system locally just fine and determined the network in the RV is functioning. The portal shows data from 8 months ago and has not updated since but then is then switches to realtime reporting and I then get updated to the second stats but that process has now stopped.
Is there a process to kickstart realtime reporting?
VRMmonitoring
Alexandra avatar image
Alexandra answered ·
@bcoffel
Reboot the gx device. And check your internet connection.
You can check if it is sending data online through the menu, settings -vrm online portal - last contact
bcoffel avatar image bcoffel commented ·
Alexandra, thanks for the help it started reporting again but it only lasted a day before it stopped. For some reason historical reporting stopped 8 months ago, is there a way to reset it so that it starts up again, perhaps this is aggravating the realtime reporting issue?
-bob
kevgermany avatar image
kevgermany answered ·
Quite a few VRM posts at the moment. Probably teething problems with all the recent enhancements. Please be patient.
