cohenfive avatar image
Smartshut Won't Stay Connected...
I have a smartshunt attached to the battery of our camper trailer. The first few weeks connectivity was fine, and since then it has been terrible. This is the second time I've been unable to connect via bluetooth, standing right next to the battery and smartshunt (maybe 1 foot away with no metal objects in between). I guess I can un-pair it and re-pair it again, but if I have to continue doing this every time I want to see what is going on with my battery it is going to get old really fast. Any ideas or tips would be much appreciated. I know these devices get very good ratings, but so far my experience has not been good. Thanks.
smartshuntBluetooth
devodave avatar image
devodave answered ·
Try a different model phone. Some phones have real issues.
Please explain you issue a bit more.
Do you see the SmartShunt in the VictronConnect device list and can't connect or do you not see it in the device list?
frankdg avatar image
frankdg answered ·
Hi all
I have a similar problem since a few days......
I use an "older" iPhone 6 (without simcard) only to monitoring the Smart Shunt and both MPPT plus a IP22 via BT
All Victron devices are also showed in the BT-list....
Since a few days the Smart Shunt stops "measuring" and the info stays "blocked"
I disconnected already a few times de 12V (by open the little fuseholder) from the Smart Shunt near de Lifepo4 battery
The connections by the fuseholder are clean and ok.....
I delete already a few times de Victron app from the iPhone 6 and re-installed
I delete all "history" from de iPhone and and switch them complete off
When I see that the Smart Shunt stops measuring I am going out of the app by touching the "arrow" left on top....
Than I "delete" the last pages I opened ( during the test it was only the "page" from the Smart Shunt
When I open than again the Victron app the BT-signal next the Smart Shunt icon is back there and the "measuring" starts again....
I use also a iPhone 7 and I did the same test with the same results......
What could be the cause ?
Best Regards
Frank
