malibudave42 avatar image
malibudave42 asked
SmartShunt placement for best Bluetooth connectivity
I'm about to purchase a SmartShunt -- love the concept!. I see in this forum there are some folks experiencing Bluetooth connectivity issues. As with any radio, it can be interfered with by EMI and metal structure obstruction. I plan to use the SmartShunt in my 5th wheel. The front compartment has the batteries, charge controllers, etc. and all electrical wiring. I suspect quite a bit of EMI in this compartment. Since all current goes through the negative side of the shunt, near-to-battery placement makes sense to reduce current loss... in other words, the Bluetooth transmitter is located next to the worst EMI.
Where is the best placement for the SmartShunt?
SmartShuntBluetooth
seb71 avatar image
seb71 answered ยท
In this case, maybe get a BMV-712 instead. It has a separate display with the bluetooth module inside, which you can mount inside the living space away from the EMI sources.
seb71 avatar image seb71 commented ยท
My message was edited. Not by me. I don't like this.
0 Likes 0 ยท
