voiptools avatar image
voiptools asked
Victron Energy SmartShunt 500 amp Battery Monitor (Bluetooth): Help with settings
I have two Lithium batteries for my RV. Model: Lion Safari UT1300. What should I use for settings. I'm pretty clueless when it comes to electrical stuff. This is what it says on the product specification page:
  • Battery Type Lithium Ion
  • Battery Chemistry Lithium Iron Phosphate (LiFePO4)
  • Rated Capacity 12.8V / 105Ah / 1344Wh / 150A
  • Cycle Life 3500+ & 100% DoD
  • Weight 23 Pounds
  • Dimensions 10.2" L X 6.6" W X 8.8" H (9.8" H to top of post)
  • Max Charge Rate 100A
  • Max Charge Voltage 14.6V
Lithium BatterySmartShuntBluetooth
Paul B avatar image
Paul B answered ·
the 105A/h then it mentions 150A so its not to clear what the battery capacity is, presuming its 15 Amp our battery then the below is the battery setup for what you have, Subject to the charging setting of your charging system is set to 14v or over under absorption.
Also have a look at this video on how SOC and the bat monitor is setup as this may help you in understanding its operation
https://octopusasia.com/battery-monitor-and-soc-state-of-charge/
