ironmancole avatar image
ironmancole asked
48v Multiplus Invertor with 12v batteries
I'm fitting out my boat and have bought a 48v Victron Multiplus 8kw Charger Invertor. I went big as I'm looking to reduce my reliance on gas and got fed up with a 3kw invertor and the limitations of it when I want to run a lot of items. I also bought 4 x 205ah 12 volt batteries to satisfy the 48v, which I believe have to be wired in series.
I am told that if I wire in series then I effectively lose the 820ah potential of 4 batteries and would only in effect have the ah of just the one battery, or 205 ah.
Can anyone advise if this is correct and how I would go about accessing the 800+ amp hours I thought I'd got access to? Do I need 16 batteries to achieve 820 ah or can I in fact wire in parallel whilst keeping the invertor happy?
Thanks for any guidance here, I'm out of my depth :)
Multiplus-IIbatteryvictron
seb71 avatar image
seb71 answered ·
You don't "lose" anything. You just have wrong knowledge.
If you wire those four 12V 205Ah batteries in parallel,
you will have a battery with
205Ah x 4 = 820Ah,
but at 12V.
The energy stored is 12V x 820Ah = 9840Wh.
If you wire those four 12V 205Ah batteries in series,
205Ah
but at 12V x 4 = 48V.
The energy stored is 48V x 205Ah = 9840Wh.
As you can see, the energy stored is the same.
Notes:
  1. 12V / 48V are nominal voltages. The actual voltage varies.
  2. You can't use the entire capacity.
  3. For using that 48V invertor, you must wire the four 12V batteries in series.
billknny avatar image
billknny answered ·
You have been told correctly.
If you wire the batteries in SERIES you increase the voltage, but the available Amp-Hours does not increase over the single battery rating. Four 205 Amp-hr, 12V batteries in series can supply 205 Amp-hrs at 48 Volts.
If you wire the batteries in parallel you do get 820 Amp-hrs, but only at 12 Volts. The inverter will not work.
The amount of ENERGY available is the same in both cases. Four 12 volt 205 Amp-hr batteries in series, or in parallel, in any combination, supply 9840 Watt-hrs of energy.
To have a 820 Amp-hr, 48V battery bank using 12V/205Amp-hr batteries you would need to have four parallel strings of four batteries in series (16 total). That would be a 39.4 kiloWatt-hr battery bank.
If these very basic electrical calculations are a mystery to you, I suggest you not go about designing this system yourself. Seriously.
kevgermany avatar image
kevgermany answered ·
You have lost nothing. As the batteries are going to be in series, you have 205AH at 48V. It's the same amount of power, but as the voltage is 4* higher, you use one quarter of the amps.
Power = Volts * Amps.
So
205 * (12 * 4) = 205 * 48 = 9840W
But... you're maybe undersized on the batteries if you're going to really use the 8KW.
sharpener avatar image
sharpener answered ·
Actually @kevgermany the units are wrong. The capacity is 205Ah and the stored energy is 9840 Wh.
If the OP is really planning to have 8kW of load, this size battery is going to last a little over 1 hour before it is flat. How is he intending to recharge it in a reasonable time, from the engine? from solar PV? from shore power?
Read op again. He said he installed 8kW for future expansion. He did not mention actual load. Agree the batteries are undersized.
Yes, thanks I missed the hours out.
