bskz avatar image
VE.Bus BMS and BlueSolar MTTP solar charger
Will VE.Bus BMS disconnect solar charger if it is connected through Venus controller in stead of direct connection between VE.Bus BMS and solar charger? It is 3 parallel Victron MultiPlus 48V, Victron VE.Bus BMS, 2 Victron smart LFP batteries in series, 2 Victron MTTP BlueSolar chargers all connected to Victron Venus controller in heart.
Venus GX - VGXBMS
Sarah avatar image
Sarah answered ·
The BMS should be able to control both the Multiplus and MPPT controllers charge algorithms and the ATC / ATD settings. This may operate a bit differently (current limiting setting) if you are using a beta version of the Venus software.
f05ed25d-4942-4066-b515-92b06417dbee.jpegImage Caption
bskz avatar image
bskz answered ·
Am O doing something wrong? Or I misunderstood the point? Thanks!
