petep avatar image
petep asked
Multiplus Compact 12/1600/70 not charging on shore power and no led light charging only
My Multiplus Compact is not charging when I'm connected to shore power.
I cant find any solutions and am not sure if I have to look to "hardware" or software issues.
My setup
Multiplus compact 12/1600/70,MPPT,BMV 702,AGM 12v/220
I specially wondering if the software settings are correct and if I should update the firmware ( and which version ?)
Maybe the charging is not been activated because of wrong settings ?
Hope someone can help me !
MultiPlus Quattro Inverter Chargerbattery chargingshorepower
On all your screenshots there is no AC IN voltage.
Check the AC wiring on the input and use a multi-meter to measure the voltage.
