jonpoe avatar image
jonpoe asked
Lynx Shunt to Cerbo GX VE.Can port ERROR-PASSIVE TEC:128
I have a Lynx Shunt VE.Can that will not show up on my Cerbo GX as a VE.Can device. Other VE.Can devices will show up, but I have disconnected them for troubleshooting the shunt. I have a Cat6 UTP RJ45 cable connected directly between the VE.Can ports on the shunt and the Cerbo, with a blue terminator plug on both ends. The shunt's LED is green and current is flowing. RJ11 cables are connected to Lynx Distributers left (batteries) and right (loads) of the shunt. The VE.Can port status page from the Cerbo interface is attached.
Please let me know any suggestions or additional info needed.
Thank you!
cerbo gxVE.Canlynx shunt
Hi, sorry to hear that!
And with the lynx shunt removed, and other devices connected, does all work ok?
Ie shows error-active rather than error-passive, etc?
in that case I’m afraid your lynx shunt is broken. You could check the 8 pins in the RJ45 connectors, to make sure they’re not bent. But other than that, the only thing that can be done is getting it repaired or replaced.
Sorry for that.
Ps: ERROR-ACTIVE is the normal and good state. ERROR-PASSIVE is comms “degraded” state. And next level would be BUS-OFF, which means no longer communicating on the bus. This is a good read about it: https://www.kvaser.com/about-can/the-can-protocol/can-error-handling/
Lynx Shunt VE Can online manual
Cerbo GX product page
GX family product range
Cerbo GX & GX Touch datasheet
Cerbo GX Manual
Venus root access document
