memilanuk avatar image
memilanuk asked
MultiPlus not showing up in Victron Connect
Finally got the MultiPlus 2k Compact wired up to AC power and charging my two SOK 206 ah batteries @ 67amps. Yay!
Previously I had the MultiPlus powered up from the batteries for programming... first I set up the VE.bus Smart Dongle, updated the firmware, joined it to the same network as the Smart Shunt and 100/50 SCC. Then unplugged it from the Smart Dongle, and hooked it up to the laptop via the Mk3 USB adapter, and adjusted some parameters there and reset/rebooted the MultiPlus. Unplugged the USB adapter, and plugged the cable from the Smart Dongle back in.
The problem is that now that everything is powered up... I'm only seeing the shunt, 100/50 and the dongle - not the MultiPlus.
I thought that was the point of having the dongle, to be able to 'see' and control the MultiPlus? I realize that adjusting the settings requires the Mk3, but shouldn't I be able to 'see' it and do limited controls (turn on/off, set max AC current, etc,) via BT?
multiplus ve.busVE.Bus Smart Dongle
memilanuk answered ·
For anyone viewing this later... turned out the cable came unplugged from the dongle when I was situating the batteries in their cubby. I would have sworn I heard the cable 'click' in place, but apparently not...
