travellinground avatar image
travellinground asked
Adding Victron to existing grid-tied Gen24 + BYD HVS system
I have an existing grid-tied system with a 7kW of panels to a Primo 6kWh Gen24 with 7.7kW of BYD HVS hooked up.
I would like to add a 48V Victron to the system and add batteries, probably Pylontech, and I will be adding a wind turbine to this system, but not initially. What would be the best setup to not mess with my current setup too much, but such that I can fill the Pylontech batteries from both the grid and the panels?
PylontechFroniusBYD
marekp avatar image
marekp answered ·
@travellinground
I was told that Fronius GEN24 does not heave MC settings so it cannot be setup as AC-coupled for Victron.
Leave your system in front of the new Victron and Pylontechs.
Sun will first charge your BYDs and when BYDs are full, Victron will take AC-in to charge Pytlontechs.
You can also add MPPT charger (with additional panels) to charge Pylontechs directly from SUN.
Also wind turbine can charge Pylontechs.
Frank avatar image Frank commented ·
I have a large Quattro four 10Kw Inverters and want to add the Fronius Gen24 with Battery storage Has anyone done this ?
And yes the 4 Quattros are 48 volt and have already 130kwh lithium storage
Victron BYD battery compatibility guide
Victron Pylontech battery compatibility guide
