Elimac avatar image
Elimac asked
VE.Smart networking or DVCC ?
With a simple system, all DC without inverter but with a GX device + MPPT + smartshunt with temp. sensor and GEL batteries, which is the correct way to compensate temperature?
a) Enable BLE smart.network and join MPPT and smartshunt; or
b) Enable DVCC on GX device and select Smartshunt as the Battery monitor/ temperarture sensor
Or... both (not at same time) work?
MPPT SmartSolarSmartShuntBluetoothTemperature Sensortemperature compensation
Alexandra avatar image
Alexandra answered ·
@Elimac
DVCC, you already have the GX.
Smart networks are for those guys who are trying to keep the costs down, and not buy a gx. You have already spent it. Use it. And it is way easier to set up.
But yes both work to my knowlege. To be honest never tested the temperature comp as we dont use gels.
Elimac avatar image Elimac commented ·
Thanks. That's what I thought too.
nickdb avatar image
nickdb answered ·
Temp compensation works well, used it on my old gel set, just remember to multiply the compensation voltage correctly for the number of batteries in series.
Talking about GEL batteries... I can't find the correct values for absorption / float for these batteries. Datasheet says nothing. On the Internet I can't find naything either. What's with that? Do you know what would be sensible values (per cell or per 12V block) for a current GEL battery?
