ahib avatar image
ahib asked
Battery voltage remains on Smart MPPT after battery removal
Hello all,
Does anyone know why on a 100/20 MPPT, having removed a battery pack, but with the PV still connected, the app still shows 13.5V in float mode for Battery? Testing the voltage across the terminals confirms this. Is the controller trying to do something it shouldn't? Having a problem sensing presence or lack of a battery?
Thanks
MPPT SmartSolarbatterysolar
seb71 avatar image
seb71 answered ·
The problem is that you should not disconnect the battery while the PV array is still connected.
ahib avatar image ahib commented ·
Ok thanks. Can you expand a little? Will this damage anything? Or just will it confuse the app until it's given another battery?
seb71 avatar image seb71 ahib commented ·
There is a risk to damage the charge controller if it is connected to the PV array, but not connected to the battery. So avoid doing this.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
