Mikael avatar image
Mikael asked
CAN-bus BMS type A or B for new Pylontech
Hi
I have just bought two new Pylontech US2000 but just want to make sure connect the correct CAN-bus BMS cable. After what understand from
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
It should be " VE.Can to CAN-bus BMS type B Cable, part number ASS030720018"
Is this correct?
Best Regards
Mikael
Pylontechwiring
As it's written in the link.
Typ B for US2000/US3000/UP2500 and Typ A for US2000C/US3000C/UP5000/Force-L.
Mikael avatar image
Mikael answered ·
It should be easy to check via the part number or missing “C”.
The earlier models limit discharge current to 25A per battery so you can also check via the bms parameters on the GX.
lance avatar image
lance answered ·
I'm going to try this question here, as it is related but, for a Batrium BMS versus Plyontech.
Batrium says Victron will communicate with Cerbo GX. They link to a cable to use on Victron's site but, at that link is a type A and B, and nowhere does Batrium or Victron say which is the correct cable to use. I've looked for clues within Batrium's page, (https://support.batrium.com/article/110-how-to-control-victron-gx-with-watchmon) to no avail but, I've VERY limited knowledge of this stuff.... Really hoping to find someone who's actually made this connection and can do some hand holding! Currently have a Watchmon 7 but, that may be about to change to the Watchmon Core.
It looks like you have to cut off one side of the cable and connect the bare wires in that case it doesn't matter what cable you are using, you just have to use the correct wires according to the pinout of the Victron Can-port.
Victron Pylontech battery compatibility guide
