mercamper13 avatar image
mercamper13 asked
easyplus 12 / 1600 / 70 red light + click, no power, no charge
I have a camper setup with
victron easyplus 12 / 1600 / 70
2x battery victron AGM 12-220
after not using the camper for 2 weeks I saw the battery alert was on and the batterypower was only 5,5 V ( external battery monitor, not victron)
when i plug in the 220 V cable the light is red ( not blinking ) and every +- 30 sec I hear a click but nothing happens.
--> batteries not charging ( normally I see the monitor on 14,8V, now stays 5,5V
--> no 220 V measured in the sockets.
I already disconnected all the elements that can use battery-power as i suspect one of the items caused this
I bought the camper with the system so I have no history about the installation. I also found it strange that the batteries didn't charge while driving but that is poblem n°2 :)
Phoenix Invertervictron productsEasyPlus
With 5,5V the batteries are dead.
You could try to use an external charger to get them back up but they are now damaged.
You could also try to switch the easy to "charger-only" mode.
Phoenix Inverter product page
Phoenix Inverter Smart product page
