gyrex avatar image
gyrex asked
Possible to control charge state of BlueSolar/SmartSolar MPPT charge controller using MultiPlus & two-signal BMS?
Hi everyone,
Is it possible to control the charging state of a BlueSolar/SmartSolar MPPT charge controller if I use a two-signal BMS setup connected to a MultiPlus II? https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf
ie. if my BMS detects that one of the cells hits a pre-configured high voltage state and sends a signal to the MultiPlus to stop charging, is it possible to also tell the MPPT charge controller to also stop charging the battery?
MPPT ControllersMultiplus-IIBMS
gyrex avatar image
gyrex answered ·
In case anyone else happens upon this question, here's a detailed response from another thread: https://community.victronenergy.com/questions/76599/ess-with-2-wire-bms-and-mppt.html
marv21 avatar image
marv21 answered ·
yes.
If you have an GX Device / or VE.Direct thats possible.
