peternielsen avatar image
peternielsen asked
Does the Multi II control SmartSolar charger as well ?
In a installation where i have a two smartsolar MPPT chargers and one MultiPlus II and i use a propriteary BMS that i connect as described in https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf e.g using the Aux I/O and Temp sense input does the Multiplus II tell the Venus/Cerbo GX which then talks with the SmartSolar to stop charge or go into float or how does that work ?
thx in advance
/Mihai
Multiplus-IIMPPT SmartSolarBMS
