Current transformer not needed, but possibly needing depending on install but system will work without.
VE.CAN to CAN Bus cables for Pylontech is needed, should not use system without.
Lynx BMS not needed and doesn't work with Pylontech.
RS485 to USB is for computer config and not GX or will system running.
10mm2 can be correct for Multiplus-ii 5kva if correct breakers are used.
Talk to your distributor for support.
If it was a package you should ask that questions the seller from whom you bought it or ask a local Victron installer for help (you will have to pay for that service).
https://www.victronenergy.com/where-to-buy
Recommended Pylontech settings/Can.bus wiring:
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
The Lynx Smart BMS is only for the Victron Smart lithium batteries.
For that system :Is necessary to use lynx distributor ?
If yes, what kind of mega fuses (how many amberes each) have to be selected?
..and it's not a 5kW inverter. It is 5kVA - 4kW.
This is also a community site, it is not here as a substitute service for designing and consulting.
You need to go speak to whoever sold you this equipment, or the distributor that sold it to them.
There is some expensive equipment in that list, easily damaged if someone does not know what they are doing.
Victron Pylontech battery compatibility guide
34 People are following this question.
