In the past I could see the values of the individual trackers of my MPPT RS on the VRM portal. But this has now disappeared, in the advanced dashboard i can still see the details. Is that something that has been removed a gain or a bug?
This issue should be fixed now. There was indeed a bug in the logic for displaying and sorting MPPT RS device details on the dashboard.
I seem to recall this is a known issue and has probably to do with two changes recently wrt MPPT chargers. The first being the change from PV A to kW readings and having to derive the A from the kW. The second is the RS itself, with two trackers in one device, which has it's PV data in a different location than the other single MPPT chargers.
I have seen a similar problem. In fact the VRM has become virtually unusable in addition in the last several days. I’ve tried the app on Apple , Samsung web browser on 3 different devices and it’s permanently locking up or not updating.
Not sure what’s happened to it but it’s totally f****ed up
Hello everyone, I have had also problems running VRM the last few days. The dashboard doesn't update or hang. The remote console is practically inoperable because it either reacts extremely delayed or does not react at all. My system consits 3x MPPT RS 450/100 + 3x MP II 48/5000 + 16x Pylontech US3000C. Regards Chris
Do you mean like this?
If so then I also get it from time to time.How to change the Owner of a VRM installation
39 People are following this question.
