Oliver avatar image
Oliver asked
Charging power not balanced between 3-phase Multipluses
Three Multiplus 5000 form a three phase system. When running the generator we observe that basically only L3 is doing the charging. But I expect to see the charging current somehow evenly distributed between the phases.
We are running CCGX 2.66 and VE.Bus 482.
DVCC is on with current limit of 200A.
The same config settings were sent to all Multipluses.
Any idea how to solve this? I appreciate any hint. Thank you
Kind regards
battery chargingGeneratormultiplus ve.bus3 phase
basil katakuzinos avatar image
basil katakuzinos answered ·
All i can think of is that the charging settings where only sent to the L3 inverter. Are you 100% sure the same settings where set to all?
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
