wbe avatar image
wbe asked
Easy Solar 3000VA 24V Overload
Inverter goes into overload fault mode as soon as you switch from off to inverter. (Charger only) works perfectly fine. How is it going into overload when there is nothing connected?
MultiPlus Quattro Inverter ChargerEasySolar All-in-Onefault
Vangelis Beligiannis avatar image
Vangelis Beligiannis answered ·
I had the same issue in an installation. It turned out that the internal dc fuse of the Multiplus was defective. So they Just changed the fuses and it worked fine
