stricky avatar image
stricky asked
DC Cut off when Battery Soc is below 25%
i want to cut off my dc lines, when the soc of my pylontechs below 25% percent.
i want to connect a high current relais to relais 1 of my cerbo gx...
how can i do that ? Only with the generator start / stop function ? in my opinion, the menu for that is much overloaded ...
is there another chance to do that easily and maybe for relais 2 as well ?
regards
christian
cerbo gxPylontechdc system
Alexandra avatar image
Alexandra answered ·
@stricky
Second relay is manual trigger only. The first is controlled by the generator start stop.
https://community.victronenergy.com/questions/64127/cerbo-gx-relays.html
You could always use a battery protect to disconnect your DC loads.
