aph avatar image
aph asked
Using Phoenix 12/1200 with Krups Essenza Mini capsule coffee maker
Hi all,
I am trying to use the above capsule coffeemaker withe my Phoenix 12/1200. The coffeemaker is modified and has a prolonged heating phase so that it uses 700-800 Watt
problem is that the inverter goes into overload reboot 90% of the times I try to draw a coffee. I also have the fluttering sound effect described here and here.
The inverter is connected to a 150Ah LiFePo battery via 50cm of 25mm2 wirering run over a high power fuse.
in this setup I am able to deploy a 1000W electrical waterboiler as well as a hair dryer on the Phoenix 12/1200 without problems.
the capsule Maschine runs without any problems on a Votronic SMI600-NVS, 600-1200 Watt.
Any ideas why this isn’t working aus expected?
Cheers Arne
Phoenix Inverter
aph avatar image
aph answered ·
Nobody a clue?
