hanno-bisschoff avatar image
hanno-bisschoff asked
Inverter Serial nr from a Remote VE.Bus system
Hi
I have recently installed a VE.Bus system in a remote location. (Color Control, 2 x MultiPlus1 inverters, Smart Solar etc.)
I would just like to know if it is possible to obtain the serial numbers of both inverters. Normally I would just get the device serial numbers from the VRM portal but since it is a VE.Bus system it does not show the serial numbers of both inverters.
Thanks in advance!
MultiPlus Quattro Inverter ChargerVRMVE.Bus
Paul B avatar image
Paul B answered ·
If you go to the vrm and select devices then download the configuration and open this up with the vebus configurer program then open each unirs configuration and the number is along the top line
hanno-bisschoff avatar image hanno-bisschoff commented ·
Oh my goodness how did I miss that! Thanks @Paul B really appreciate it
