This question was closed by magicmike for the following reason: The question is answered, right answer was accepted
magicmike avatar image
MK-3 USB / VEFlash Error at step 'Connect part 2'
I have multiplus 40/3000 and my old FW is:
2620158 i believe i need 2620159 with im trying to update.
But having error.
I dont have problem to VeConfig, Victron Connect does not work becouse my FW is to old.
Swapped device, changed ports and all... still no luck.
Tried to google solution but cant find any,
I want to update FW and go with Generator configuration as every 60 sec there is a swap between charger to inverter.
I've tried another ethernet port and no luck still.
I'm under off grid so I only has batteries connected.
Firmware Update Issuefirmware updateMK3
Paul B avatar image
Paul B answered ·
The fW to go up to is 2620486
also MAKE sure you do not have ANY other devices connected to the VE bus port only the MK2 unit
4 comments
Ok! i ll try again tomorrow. Thank you!
But i cannot find 2620486 at all on V-Professional.
487 should be the latest version by now.
2620487 is there now, use that one.
ok! i ll try in morning :)
magicmike answered ·
Still having error but I'd say I ll give up. :)
