Marcel avatar image
Marcel asked
Trouble updating RPI 3B+ V2.66 to large image
I 'm trying to setup a VenusOS large image on my RaspberryPi 3B+.
I followed the guidelines from https://www.victronenergy.com/live/venus-os:large
I've downloaded a regular V2.66 image. Then I copied several files from the dropbox link. I formatted my USB stick FAT32 and verified it via SSH that the files are accesible via /run/media/sda1
However when I try to select the offline installer via the webconsole the system responded with a message "no firmware found"
I've tried the following files:
venus-image-large-raspberrypi2-20210416104645-v2.70~5-large-18.rootfs.wic.gz
venus-image-large-raspberrypi2-20210807060818-v2.72-large-19.rootfs(1).wic.gz
venus-image-large-raspberrypi2-20210807060818-v2.72-large-19.rootfs.wic.gz
venus-image-raspberrypi2.wic.gz
venus-swu-2-raspberrypi2-20210416104645-v2.70~5-large-18.swu
venus-swu-2-raspberrypi2-20210807060818-v2.72-large-19(1).swu
venus-swu-2-raspberrypi2-20210807060818-v2.72-large-19.swu
venus-swu-2-raspberrypi2-20210810140320-v2.80~11-large-20.swu
root@raspberrypi2:/media/sda1#
Still I get the message no firmware found.
Anyone an idea where I went wrong?
Thanks for helping me out
regards
Marcel
Venus OSfirmware updateRaspberry Pi
Marcel avatar image Marcel commented ·
In adittion to my post:
When I try to change logging from internal memory to USB it comes back with a message: No storage found
Marcel avatar image
Marcel answered ·
I found an answer:
https://community.victronenergy.com/questions/93584/raspberry-pi-3b-update-to-271.html
I therefore asume something is missing in the description on the page of the Venus OS Large image.
I flashed a v2.71 image from the following link:
Image direct: http://updates.victronenergy.com/feeds/venus/release/images/raspberrypi2/venus-image-raspberrypi2-20210621155055-v2.71.rootfs.wic.gz
After re inserting my SD card in the RasPi and booting it up I got the option to update it from the USB flashdrive.
That resulted in a v2.8 large image.
Good its solved. There is a newer v2.80 large file for the rpi3 on my computer, I’ll put it on the dropbox tonight
also I added a bit of text to the manual, to make it more clear: https://www.victronenergy.com/live/doku.php?id=venus-os%3Alarge&sectok=8fd8b9b1333d4dc2fd6b055b30f2765b&do=revisions
Hi Matthijs, I've seen the changes in the text you've made. I think that's perfect.
I've updated my PI with the new image (venus-swu-2-raspberrypi2-20210911213250-v2.80~17-large-22.swu)
Thanks for your help
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
