k10 avatar image
Campervan Connecting 3 types of charging - Alternator / Solar / 240v
I currently have the following Victron products and want to add solar and 240v charging to my system
I also need to add some more 12v appliances and upgrade the current battery for a trip
Here is what I have currently
1 Cyrix CT 230a connecting the starter and 100ah AGM battery
2 BMV712 and Shunt
I have individually fused connections to the battery for DC loads (Fridge and lights) and want to tidy it all up when adding the solar and mains charging
Is the following diagram the correct way to incorporate the solar controller and 230v charger ?
Specifically should I connect all the 3 charging inputs positives to the POS BUS BAR and all the Negatives to the SHUNT ? if so which side ?
battery chargingchargersolar
pau1phi11ips avatar image
pau1phi11ips answered ·
Looks good to me.
I think this would've been better to ask in the Q&A forum instead of the Modifications one btw.
k10 avatar image
k10 answered ·
thanks - moved to Q&A
