armstead81 avatar image
armstead81 asked
IP65 charger and smart shunt
I'm going to install an IP65 charger to my system because ad the moment I can't recharge the battery from Orion, we are in lockdown. The question is, do I need to connect the positive to the Victron lithium battery and the negative to the smart shunt or both to the battery? In which order or doesn't matter? Unfortunately, I can't drop the car at the auto electrician's and my 12v knowledge is about zero and I'm desperate.
chargerSmartShuntip65
wkirby avatar image
wkirby answered ·
Connect the positive of the IP65 to the battery positive. Then connect the IP65 negative to the "SYSTEM MINUS" terminal of the smart shunt.
