expedition avatar image
expedition asked
Need system recommendation.
I need a system recommendation. System is Offgrid 48V 350A Lithium. 6 x 465w Solar panels. AC Generator. Original I was going to put 2 Easy solar 2 3000. As I need the 2 mppt, need the GX and need the 6000 inverter charger.
Now I read I cannot put 2 in parallel because only 1 GX is allowed. So I can replace 1 easy solar for 1 multiplus 3000 but have to add another mppt.
I check about RS 48/6000, it has it all for me except Charger and cannot plug the AC generator.
Thanks!
Phoenix Inverter
There will be a Multi RS Solar 48/6000/80-400/80 maybe available in September.
It is already in the pricelist PMR482602000.
expedition avatar image expedition commented ·
I think that doesn’t have ac battery charger that I need it order to plug the ac generator.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ expedition commented ·
As any other Multi it have an AC input and a charger build in.
48V/6000VA/80A charging current from AC input - 450V PV/80A charging current from PV.
expedition avatar image expedition Matthias Lange - DE ♦ commented ·
Thanks! That should be the perfect unit for my needs.
