I am using a 40A Solar Charge Controller and wonder why one would have a battery charger connected all the time? If I am charging my batteries via solar, doesn't the charger defeat the purpose?
I’m using a different charger, a MultiPlus, but I think the concept still fits. Both devices are battery chargers, so it might seem like having two on is pointless, but they do operate a bit differently, and complement each other.
A charger senses battery voltage, comes on when needed, follows a charge program, then turns off. It cares not whether the sun is shining.
A SCC also reads battery charge, and provides voltage to charge batteries and carry system loads when incoming PV is available. Absent any system loading, it acts pretty much like a battery charger, following a charge profile. As long as there is adequate incoming PV, it’ll supply charge and load power until the battery is charged (the whole system comes up to 100% charge voltage). But, no sun… no power.
The nice thing about having both, set correctly, is that it is a “belt & suspenders“ approach that happens automatically. The charger will remain off as long as the SCC is providing sufficient power, and will kick on when PV either isn’t up to the needs or unavailable altogether.
So you don’t have to have both all the time, but (set correctly) they play very nicely together!
27 People are following this question.
