Kevin Windrem avatar image
Kevin Windrem asked
Prevent VRM storage on USB/SD media?
Is there a way to prevent logging to a USB or SD memory stick?
When a memory stick is inserted it automatically becomes the place off-line VRM data is stored. However, if there's a .swu file on the stick this does not happen. There are other reasons to insert a memory stick like updating other software (for example my GuiMods package) and this should not be used for VRM storage.
Yes, I know if there is another memory stick installed that IS being used for VRM off-line storage, a new stick will not become the logging source, but I'm not sure we can rely on this especially if USB ports are limited.
VRMVenus OS
Mark avatar image
Mark answered ·
Hi Kevin, super nice work with all your GUI mods and a credit to you for all the hours you have put in and shared with the wider Victron community.
Have you tried to simply add a random file with the .swu extension onto the same flash/USB drive?
Kevin Windrem avatar image Kevin Windrem commented ·
Good idea, but it doesn't work.
I can add an empty file named venus.swu and that prevents logging.
Inserting the memory stick does change menu focus to the software update page though where it reports an error.
