muelli avatar image
muelli asked
Phase Cut power regulator
I have a small 250VA victron phoenix inverter and trouble using a phase cut power regulator. When connecting said regulator, the inverter makes a very loud humming noise and voltage level rises about 20V from 230V to 250V.
It sounds (and the values look) very unhealthy, so I disconnected it immediately.
Without that regulator the inverter works normally....
Any ideas what is wrong?
Phoenix Inverter
@muelli
They use thyristor or triac based control, they 'cut' (as the name suggests) the sine wave. The back emf from these circuits are a problem for inverters, especially ones that synchronise with grid frequency.
muelli avatar image
muelli answered ·
Yeah I thought so, I wanted to use it to regulate a heater element, but then I will just use a transformer for that purpose.
@muelli
Yeah the noise is a bit disconcerting. A side effect of the transformer in there interacting with the case.
