jorisvn avatar image
jorisvn asked
Is there a time/clock function to use in programming ACOut2 virtual assistant?
Dear all,
In case there is grid power available I would like to turn of my ACOut2 at 22hrs and turn it back on at 5.30hrs. So the geysers and fridges are not working through the night. Is there a way how I can manage this in a virtual assistant?
I have the following assistant rules in place in case there is no grid available to turn of ACOut2 to avoid my batteries run flat before the sun comes up. (and alarm goes off etc) With these settings the ACOut2 will go off between 19-20hrs. (and come back when the sun is blazing around 8.30hrs) That is fine in case there is an issue with the grid, but not for structural use. Any tips?
Or is there another workaround to create an assistant with "AND" logic iso "OR" for the rules?
Thanks.
Venus GX - VGXAssistantsac out 2
No, there is no RTC inside the Multi.
Maybe you could use an external timer (or the relay of your GX device) connected to the AUX input and use that signal.
VEConfigure Assistants manual
Venus GX manual
Venus GX product page
