niccolaiddis avatar image
niccolaiddis asked
Quattro 48/3000 and BYD LVL 15.4. Are they compatible?
Hello everybody,
I have two Quattros 48/3000 connected in parallel, single phase.
In the Victron Compatibility page it says the following: "All 48V Multis, MultiPlusses, MultiGrids and Quattros are compatible".
...but then there's this table:
As you can see, the Quattro 48/3000 is not mentioned.
It's the same inside the document "Minimum Configuration List" made available by BYD, see below:
...am I missing something? Is the 48/3000 compatible with the BYD LVL 15.4?
Thank you for your help
MultiPlus Quattro Inverter ChargerEasySolar All-in-OneBYD
Alexandra avatar image
Alexandra answered ·
@niccolaiddis
Possibly just a small oversight in the table.
It would have same requirements as a 48/3000 Multiplus.
I don't see why it would not be compatible. It would make no sense that it is the only 48V on that cannot be used.
niccolaiddis answered ·
@Alexandra
I thought the same, but then I found the table from BYD, that's what made me think that maybe there's a problem I didn't realize?
@niccolaiddis
I will chat to a few people and double check. I have not personally used the BYD LVL 15.4.
niccolaiddis avatar image niccolaiddis Alexandra ♦ commented ·
Thank you!
@Alexandra
A couple of days ago I contacted BYD asking the same question, and they just replied with the following:
"The LVL is a product we sell predominantly outside the America's as it is not UL. As a result the compatibility list current only lists the non-UL/ROW products from our inverter partners. It is believed that the LVL is compatible with the 48/3000 as the compatibility is with the Venus device, but we need Victron to confirm. We should have an answer shortly."
