rainer avatar image
rainer asked
Casing for CANvu GX?
CANvu GX is suggested to be used for harsh environments and is the only GX device that supports an extended temperature range up to 70 degrees.
Therefore I want to use this GX device.
However, there is no wall mount for CANvu GX and also no mounting for the IO extension and wiring kit. How are other users installing this GX device? In what type of box are other users installing this GX device?
Thank you.
EasySolar All-in-Onegx device
