fabiob avatar image
fabiob asked
PHOENIX INVERTER 12/1200 230V SETTING
HELLO
when I connect a 65w class a ++ minibar to the Phoenix 12/1200 230v inverter the inverter immediately switches off and generates the "low battery voltage" alarm but the batteries (2 AGM batteries of 100ah each) are fully charged and are new.
Can someone tell me what the problem can be and especially how to set the inverter parameters via Ve_direct_bluetooth
Phoenix Inverter
What wire gauge did you use? How long is the wire from battery to inverter?
If the wire is to small/long that can cause a voltage drop that will cause a low voltage cut-off at the inverter.
