Jonathan Carrasco avatar image
Jonathan Carrasco asked
Cerbo GX connection to multiple MPPT not parallel
Hello everyone, I am almost confuse about to monitoring 3 MPPT Smartolar charge controllers that we are going to connect to the Cerbo GX. Because the solar installation is more than 20 years old, "unfortunately" we have 3 string of solar panels connected with 3 battery banks and after by schottky diodes to the load (MM.WW. system), but we can´t optimize the banks because the space of each one is limited to joint them on one battery bank. for that reason we should monitor each MPPT Charge controller separately. Is it possible to monitor each MPPT (PV power, BAT power and load consume) or each MPPT should be connected to a GX device?.
Thanks for your support.
Jonathan Carrasco from Chile
MPPT Controllersbattery chargingcerbo gxbattery
