rona avatar image
rona asked
testing vebus bms
I read in the lynx bms installation manual that you can determine if the bms or the battery to bms cables are bad. Method is to connect spare cable between bms connections to test function of bms.
So can I test the vebus bms the same way as the lynx ?
BMS
