wior0474 avatar image
wior0474 asked
Small BMS in use with other charge controller
I am trying to set up a remote monitoring system for a single panel and battery system. I have a LiFePO4 smart battery for my system. I believe the small BMS is the best option for my situation. Before I purchase it I would like to know if it is compatible with other (non-victron) charge controllers? Other MPPTs suit my needs better does the small BMS need to be connected to an MPPT? Do I need a shut off, such as the battery protect, as well?
BMV Battery MonitorBMSBattery Protect
Paul B avatar image
Paul B answered ·
The small BMS has a low voltage cell output and a high voltage cell output signal
and yes you would also need some form of battery cutoff for load and charge is recomended
