Mike Dorsett avatar image
Mike Dorsett asked
Smart Solar won't connect to Venus OS on raspberry pi
I Have a raspberry pi running Venus osV2.72~4 (candidate). [I've also tried this with 2.71 and 2.72 release versions - but these don't have the Bluetooth menu]. The problem is that the MPPT Smart Solar 100/50 is not recognised either by VE direct or Bluetooth. Both the Smart Solar and the Pi are visible in the Victron connect app on my phone. I can understand (possibly) the MPPT not appearing on VE direct as the interface may have some problem (- it's giving some strange results with another app, but most of the data is there) but why is the MPPT not connecting by Bluetooth? Is this a known issue with the Venus OS on the Pi?
Also, Why does the Bluetooth menu on the LAN remote console not have a "scan" button like all other Bluetooth apps? This would add some confidence that the OS is actually going looking for the Bluetooth signal....
Venus OSRaspberry PiBluetooth
Mark avatar image
Mark answered ·
It is not possible to 'Bluetooth pair' a Victron product with a GX device (be it a genuine Victron device such as a CerboGX or a RPi setup). The Bluetooth functionality on a GX device is limited to connection with a Bluetooth device (like a phone or tablet) for setup, etc.
The only way to interface a SmartSolar MPPT is via the VE.Direct interface (or VE.Can if it is a VE.Can model). And since you are using a RPi, you will need a VE.Direct to USB adaptor cable, which I expect you already know.
Mike Dorsett avatar image Mike Dorsett commented ·
it would be nice if this was possible...
Looks like the VD direct adapter will need to be replaced.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
VictronConnect bluetooth troubleshooting guide
