I also have one of these batteries and want to know more about it. Where did you get yours?
Thanks
Dear friend I need help. How to charge this lithium battery 60v 60v 46ah 2.7 kw Pack Battery 15 x 4v 60 Volt Rechargeable ' Lithium iron . Someone can help me. Thank you very much. Michele
Please get a battery expert involved here!!
a 4V cell is -not- lithium-iron, please be careful!!!
when miss-treated this battery will catch fire
Would you have any more details about the battery? Manufacturer / Model data?
Otherwise, most 48V chargers will go to 62 - 63V on Absorption, which should be able to charge this battery to 4.2V per cell. To go beyond this, you would need the maximum cell voltage and compare this with the equalisation voltage settings of the charger.
Dear friend thank you very much for your reply
I tried to connect this ones but show me fault and doesn’t start
Did you check the output voltage before and after connecting to the battery? You may need one of the Victron chargers to be able to set the output voltage for correct operation....
38 People are following this question.
