yansangy avatar image
yansangy asked
setting low voltage cut out with Victron App
hello,
I have just started setting up my first lithium leisure battery system for a motorhome.
I have ...
- 20A Victron MPPT SmartSolar 100/20
- Victron Phoenix 800W, 12V inverter with smart dongle
- 250W solar panel
My battery does have does not have dedicated BMS so I was hoping to run my load through the MPPT and programme a low voltage cut out voltage via the app.
Similarly i would programme a cut out on via the app for the inverter which will be directly connected to the battery
However, when I did a test set up and set a user defined algorithm to cut out at a high 13.3 V, and plugged in a 12 V fridge and the voltage dropped below 13.3V, the supply to the fridge did not cut out! am i doing something wrong?
Thanks in advance for you help
MPPT ControllersLithium Batteryvoltage
papagoy avatar image
papagoy answered ·
From my experience trying to get an MPPT 75/15 to do something similiar:
- Did you wait 2 minutes?
For some of the algorithms the relay only activates when the condition has been sustained for 2 minutes.
- Do you have the right user algorithm ?
For one the switch only works when the voltage passes through the threshold in one direction.
i.e. ON > 13.3v may turn it on when it passes above 13.3 V, but not off when it passes below.
You may need the ON > 14.2V OFF < 13.3V for a fridge application, so it only turns on when you have full charge for over 2 minutes and then turns off when passing below 13.3V and staying below that level for 2 minutes.
The other algorithm is set up for a charger, where it turns on passing to below the low voltage and off when it has reached the high voltage.
Battery Compatibility
MPPT Product Page
MPPT Error codes
