benji avatar image
benji asked
BMS LED ligth
I have installed two LiFePO4 batteries of 160 Ah each. also the Ve.Bus BMS installed. I connected this to an inverter 24/3000. the inverter 25/3000 is connected to a CCGX. the batteries are powered by photovoltaic cells. I have a solararchitor MPPT 100/15 and a solarcharger MPPT 150/35 connected. there is no direct connection between the solar bearer and the bms. the solar archers are connected to the CCGX. that works too. the inverter gives off 230 volts. but now the LEDs light blue and red on the BMS at the same time. Is it okay? or do I have to change something?
BMS
Paul B avatar image
Paul B answered ·
have you added the BMS assistant to the 24/3000 otherwise the VE bms will not turn off the inverter
benji avatar image benji commented ·
yes I have added the bms to the inverter
