Colin Mills avatar image
Colin Mills asked
How to protect your batteries against a failed Multiplus?
Many know that a battery protect cannot be connected between a Multiplus and the batteries. So if while unattended, the Multiplus throws a wobbly and either continuously charges or discharges the batteries, what can be used to disconnected it when the voltage exceeds some pre-defined limit? I know when it's working it will look after the batteries. My concern is when it fails. With a separate charger and inverter, a couple of battery disconnects could be used, but not with an inverter/charger.
I know many LiFePO4 batteries have a built in BMS which will disconnect them but I have a Batrium BMS which will ask the Multiplus (via the CAN bus and Color GX) to stop but cannot actually disconnect it.
I supposed I could use a big relay but I don't like the idea of having a permanently energised relay in the system.
I guess I'm looking for a 250A (I have the Multiplus 3KVA) common port battery disconnect.
TIA
Multiplus-IIBMSBattery Protect
Meine_Energiewende avatar image
Meine_Energiewende answered ·
The Batrium Main Unit has some solid state relais which can be used to trigger a shunt trip device. This will disconnect the batteries in case of errors.
Hope it helps
Jens
Colin Mills avatar image Colin Mills commented ·
That's an idea. I don't really trust the Batrium as I regularly have to power cycle it because it loses connection to the WiFi after which I can't monitor what it's doing.
