vincentduprez avatar image
vincentduprez asked
How to use multiplus to charge engine battery in a Van ?
I'm working on a van conversion and have installed this inside :
https://www.victronenergy.fr/upload/documents/schematic-vehicle-lithium-rv2-.pdf
The only difference is that I have added victron mppt and solar panels and that I do not have the Orions, and my Multiplus is a Multiplus 800va (the one with a plastic casing 500-800-1200 versions)
The alternator can charge the lithium battery through the BMS 12/200, and the 2 circuits are independent from each other.
Now my lithium battery is fully charged says the BMV, but my starter/engine battery is low voltage.
I've seen in the user manual of the multiplus that it has a second 12v charger. but it only has a Positive (+) connector, I don't understand how I'm suppose to wire this to the starter battery
I also have a ground on the Multiplus, is his one supposed to be connected to the - of the starter battery ?
how does the second charger of the multiplus links to the negative(-) of the starter battery as it is isolated from it by the BMS 12/200.
Subsidiary question : is this second 4A charger only working when there is external 220v or does this also work from 12v energy (say my lithium is at 100% and still full sun outside on the solar panels..?
Multiplus-IIBMS
wkirby avatar image
wkirby answered ·
The only way I can think of doing this is with an isolated DC-DC converter, more gadgets.
The 4A charger on the MultiPlus only works when mains is present.
vincentduprez avatar image vincentduprez commented ·
That’s fine with mains.
But I still don’t get how the multiplus connects to the neg of the starter battery. Is it using the grounding attached to the chassis?
zuzullo avatar image
zuzullo answered ·
Hi Vincent,
Did you find out how to wire it to the starter battery?
It's the connector G. (appendix A)
The wire terminal is supplied with the unit.
nvs avatar image
nvs answered ·
  • The trickle charger terminal can be used for charging an auxiliary battery such as a starting battery. This is just the positive connection. The battery negatives must be common to each other.
