ningaloo avatar image
ningaloo asked
Phoenix 500 remote bridge / switch
I have a Phoenix 500 inverter and want to switch this on/off remotely using a 12v supply. I have removed the black jumper cable on the green bridge.
Which bridge terminal should I use for the switch supply?
My downloaded manual does not cover this.
Phoenix Inverter
wkirby avatar image
wkirby answered ·
You can connect the left hand terminal to 12V to activate the inverter.
From the manual:
3.6 Remote on/off connector A remote on/off switch can be connected to the two-pole connector. Alternatively, the left-hand contact of the connector can be switched to battery positive: useful in automotive applications, wire it to the ignition contact.
Link to the manual:
https://www.victronenergy.com/upload/documents/Manual-Phoenix-Inverter-VE.Direct-250VA-1200VA-EN-NL-FR-DE-ES-IT.pdf
