Chris Marks avatar image
Chris Marks asked
Smartshunt - positive wires for two batteries
I have two lifepo4 batteries with take offs drom both terminals of each batteries as recommending for ‘parallel’ wiring by the manufacturer of the batteries I have.
Just wiring in my smart shunt - looking at the diagram in the leaflet with the shunt it shows both positive in the vbatt and aux connections for what looks to be a series wired battery setup.
Do I need to connect both my batteries positive wise to the shunt?
battery chargingSmartShunt
wkirby avatar image
wkirby answered ·
Both of your battery modules are wired in parallel, so that effectively counts as one battery. Therefore the common positive for those should connect with one wire to the vbatt+ terminal.
The Aux is for another separate battery, like a start battery. Also could be used for mid point Voltage monitoring if two batteries modules are in series with one another. And finally the Aux could also be used for battery temperature monitoring if the temperature sensor cable is used.
